Can anyone help me identify this?
Old Jan 20, 2017 | 12:08 PM
crvols's Avatar
Default Can anyone help me identify this?
I replaced the reservoir sensor in my XJ today and everything is working fine. Before I button it up again, this plug is hanging loose and I can't identify it from the wiring diagrams. Anyone know if this is for the headlight washers I don't have? Something else I do have?
Thanks in advance.
Attached Thumbnails Can anyone help me identify this?-resized_20170120_111042.jpeg
Old Jan 22, 2017 | 11:11 PM
al_roethlisberger's Avatar
Previous discussions seem to suggest this is as you suggest, the unused hookup for the non-existent headlight washer on your car.
I have the same capped and unused connector under the washer reservoir.
Old Jan 23, 2017 | 09:02 PM
John Herbert's Avatar
Smile
Al is spot on, it is indeed the connector for the power wash pump for the headlights.
There should be a dummy relay (identified by white stripe) located in front of the relay box on the right hand side. Connections are easily identified by the thick yellow/red wire.
I have attached relevant page from wiring diagrams.
John Herbert
File Type: pdf
Old Jan 27, 2017 | 07:37 AM
crvols's Avatar
Thanks for the replies. I don't have headlight washers so I just tucked it back in where it was.
