Car still hesitating/stalling....
Old Jul 14, 2011 | 03:58 PM
MLRocafella85's Avatar
Default Car still hesitating/stalling....
hello, I just cant figure it out. I am still having a hesitation problem with the check engine light immulating for a quick second while the car hesitates and then goes away. The car will also stall once in a while. I have cleaned the throttle body, changed the MAF to a new one. Put in a new TPS Switch, a new fuel pump, cleaned out the intake, and checked for vacumm leaks and found nothing! I do not know where to look next. I still have no codes! I took the car to a local european service sop that has the newest jaguar software and tps, and maf came up, but changed both of them and nothing! same issue. If someone can help me where to look next please! thanks.
Old Jul 14, 2011 | 05:22 PM
jagqueen's Avatar
I had similar symptoms after having new spark plugs installed by my mechanic.
after a month or so fooling around with TB, mafs etc I remembered a post in this forum and replaced the new plugs with the oriiginal type champions specified by Jaguar. you should find previous postings if you do a search under stalling... my problems went away instantly despite the disbelief of many experts!
Old Jul 14, 2011 | 05:42 PM
thanks for the info, I have had my sparks done about 3-4 months ago, and the problem started about a month ago, so is that kind of long? and I used champions, just not sure which ones. Does it matter? thanks.
Old Jul 15, 2011 | 01:27 PM
genoaz's Avatar
ML, have you checked the EGR valve, be sure to clean those holes good, mine was about half clogged up
Geno
1995 xj6 184k
Old Jul 15, 2011 | 03:16 PM
yea that was my next to do thing, I actually purchased a brand new one from a guy who was selling his jag spares, got it brand new with gasket for like 60-65 bucks.
GuernseyJag
Nov 8, 2017 10:40 AM
DrScientist
Dec 9, 2015 07:36 PM
Jandreu
Aug 29, 2015 07:31 PM
SingBlueSilver
Aug 27, 2015 02:20 PM
Vector
US Lower Atlantic
Aug 26, 2015 05:36 AM
