Check Engine, bad idle
Old May 4, 2015 | 02:36 PM
khaal's Avatar
Default Check Engine, bad idle
Hi
I've read through similar threads, still not sure what the problem is.
I've had the 97 xj6l 4.0 for a year without any problem. Suddenly the idle got bad when the car was in park. The gas tank was almost empty, so I am suspecting a problem with the gas delivery?
On the other hand, from the exhaust it souds more like a ignition problem?
See video:
https://vimeo.com/126835516
The car runs "ok" in speed, but the idle is uneven and bad, there is also a lot of vibration from the engine.
I have tried to disconnect one coil at the time, but could't point out if one of them is bad.
Could changing the gas filter sort out the problem?
toronadomike
Jan 22, 2026 10:13 PM
BrentGardner
29
Dec 16, 2024 12:13 AM
fast40driver
Apr 19, 2024 07:24 AM
Thempsc
Sep 7, 2015 02:29 AM
johanasu
Sep 3, 2015 12:39 PM
