The Check List
Old Jan 6, 2009 | 03:01 PM
Doug's Avatar
Default RE: The Check List
1) Leaky hoses iis what I've heard, mostly
2) Yes, and its a big job on an XJR
3) GM 4L80E on the XJR and V12, yes. Good strong gearbox but they don't last forever. Also, weak trans mounts allows too much movement and damages the wiring connector.
4) Yes, two pumps. No more or less troublesome than any other car
5) Coil packs and crankshaft position sensors
6) Yes, memory system goes wonky. Most, like you, could care less.
7) Clock displays fails, yes. There's a work-around fix with about a 50% sucess rate.
8) Cracked exhaust manifolds
9) Suspension clunksusually shocks and/or bushings
10) Lower radiator "octopus hose" is a bear to replace. Best to change it and clean throttle body at the same time.
11) Interior lights flicker-clean door latch switches
If I think of anything else I'll post back.
You can buy these cars for peanuts...so cheap that you can hold out for a primo example and still get a bargain.
toronadomike
Jan 22, 2026 10:13 PM
trosty
26
Dec 18, 2022 06:40 PM
Rivguy
Dec 4, 2020 07:55 AM
KarimPA
Sep 12, 2015 08:15 AM
