code P1178 - problem
Old Apr 30, 2009 | 11:20 AM
panchostatus's Avatar
first off, welcome! glad to have you among our fold.
my database doesn't have a jaguar specific listing for said troublecode, but it has listings for BMW and Volkswagon, which is as close to it as you can get.
p1178 - o2 sensor signal slow circuit
bank one(1) sensor one(1).
The sensor isn't switching as quickly as it should, causing the ECU to measure the fuel/air ratio incorrectly. This is probably why you're having fuel issues also.
just a toasted oxygen sensor is what it appears to be.
I'd try changing your spark plugs if they haven't been changed in a while and then check the readings, but you will probably end up having to replace that sensor.
toronadomike
Jan 22, 2026 10:13 PM
philwarner
Oct 4, 2024 01:37 PM
Jpav27
Jul 31, 2022 06:43 AM
jdzubas
Oct 4, 2015 09:14 AM
OkieTim
Sep 2, 2015 12:48 PM
