Cooling fans overworking
Old Sep 27, 2009 | 08:05 PM
Rique's Avatar
Default Cooling fans overworking
Hello folks, I have noticed that my cooling fans are working at an extreamly high rate after driving. My temp gauge is fine at mid section always. However after pulling in at home after work on or a red light the fans are blowing like mad. Cooling water level is fine and engine runs perfectly. Any ideas what I should check for... Thanks much,
Rique
1998 XJ8.
Old Sep 28, 2009 | 04:25 AM
sparkenzap's Avatar
Rique:
The fans have two speeds. It is not unusual for them to run at high- especially if the AC is / has been on. Are you sure that maybe a blade is chipped, or a bearing is starting to raise a roar and that's what you hear?
Old Sep 28, 2009 | 08:17 AM
Max's Avatar
Max
Another thing to check is the water pump. If the XJ8's use the same OEM plastic impeller water pumps as the XK8's, the vanes will disintegrate over time, and especially if the engine overheated, and will run loud and long trying to circulate the water and bring down the temperature. These higher than normal temps are also very destructive to the plastic bodied secondary tensioners.
Old Sep 28, 2009 | 03:40 PM
Rique's Avatar
Thanks for the replys. I opened the hood when the engine was running and those fans were turning like fighter jet turbines. I beleive that my water thermostat is not opening correctly and need a changing. What do you think?
Rique
Old Sep 28, 2009 | 04:33 PM
Max's Avatar
Max
That is possible, however, usually when most thermostats fail they close and the engine temperature would shoot upwards. To be safe check both the thermostat and water pump.
Old Sep 29, 2009 | 10:37 AM
Rique's Avatar
Max, how can I check the water pump? Enrique
Old Sep 29, 2009 | 05:42 PM
Max's Avatar
Max
According to the JTIS the fans have to be removed to get the water pump out, which is probably a pain. However, the thermostat can be checked quickly by seeing if the engine temperature goes up. If it doesn't, the thermostat is probably bad. Check that first as it is the easiest.
Old Sep 29, 2009 | 10:25 PM
Rique's Avatar
Red face
Max, temp does go up to mid gauge and does not move no matter what. I will change the thermostat and give the pump a look not much more to check. Thanks Enrique
Old Sep 30, 2009 | 08:34 AM
Max's Avatar
Max
If you have a chance check E-bay for the JTIS CD. It gives the complete step-by-step directions for most repairs with diagrams and drawings. The types of things that are difficult to explain with words.
Good luck.
mikiep
Dec 20, 2019 07:37 PM
Seth
Nov 1, 2015 12:17 PM
emilime75
XJ XJ12 ( X305 )
Oct 19, 2015 09:55 PM
LnrB
Oct 13, 2015 12:45 AM
workworkwork
Oct 1, 2015 01:44 AM
