Couple of issues - 97 XJ6L
Old Jul 28, 2008 | 01:05 PM
ken@britishparts.com's Avatar
Default RE: Couple of issues - 97 XJ6L
Tune up is easy. Go for it.
Old Jul 28, 2008 | 02:16 PM
You need the JTIS manual on CD. We have them for $125.
Old Jul 29, 2008 | 10:51 AM
johnsjag's Avatar
I've got a 97 long wheel base as well with the exact same symptom @ 70mph. I had the alignment done at a non jag specialist and they could only do the front because the rear uses some shims in the adjustment, and the back was slightly out of alignment when they checked it but not to bad. I am going to have the rear done at a specialist when I switch over to winter tires so I'll let you know then. But if you solve it please post because I am wondering the same thing...
Old Jul 29, 2008 | 11:59 AM
Most Jag specialists never touch the rear alignment. I agree with Jag Genius, it's in bushings or something else.
Old Sep 9, 2008 | 08:23 AM
commercialcobb's Avatar
Mine started to shake and wobble a couple of weeks ago from the rear of the car right dead on at 70mph.. That little shake and wobble has turned into a scary 70mph message chair, it got worse in a matter of weeks, much worse.. I know my shocks are shot and I am going to replace them and have my tires re-balanced to see if maybe I slung of a counter-weight.. I let you know if this helps it at all.. I should have it done by weeks end.. [:'(]
JarodL
Mar 7, 2024 01:39 AM
trosty
26
Dec 18, 2022 06:40 PM
Rivguy
Dec 4, 2020 07:55 AM
SteveSheldon
UK & Eire
Sep 8, 2015 11:22 AM
Doovoe
XJ40 ( XJ81 )
Sep 6, 2015 10:54 AM
