Cruise Control: Light comes on...but will never engage
Old Mar 22, 2010 | 12:53 AM
TOMALONIC's Avatar
Default Cruise Control: Light comes on...but will never engage
The light comes on when you turn on the cruise function, but will never engage when you press the button. Any ideas?
Old Mar 22, 2010 | 02:20 AM
Fenja's Avatar
Could be the actuator/servo.
Old Mar 22, 2010 | 02:52 AM
panchostatus's Avatar
check ALL your vacuum lines
Old May 25, 2013 | 05:26 PM
bliving7's Avatar
Hi
Same thing for me on my '95 XJ. Turned out that the rubber bellows on the actuator was torn. I was out of town at the time so I got an inner tube patch kit and patched it. That actually worked for several months but I did replace the actuator. The patch kit can be used maybe for a diagnosis.
Good luck.
bliving7
Old May 26, 2013 | 01:48 PM
sogood's Avatar
You don't mention having any issues with your ABS, but for what it's worth, if your ABS pump or module isn't working, it can disable the cruise control. It's a bit of a clue when you get an ABS light showing, whereby, if your cruise control is still working, then the warning light is probably just a wheel speed sensor malfunctioning. An easier fix than replacing the pump and/or module.
But I would go with the vacuum actuator or a hose in this instance.
aholbro1
Dec 29, 2024 06:46 PM
Jpav27
Jul 31, 2022 06:43 AM
afterburner1
Dec 16, 2015 12:12 AM
edtexas
Sep 4, 2015 08:20 PM
XFR_Gold
Sep 2, 2015 12:24 PM
