Cylinder Numbers?
Can anyone tell me the numbers in which the cylinders are in? Is it 1-6 front to back, or vise verse, or are they random like the firing order? I need to take care of some misfire issues in specific cylinders. Thanks.
Jaguar used to number the cylinders from rear to front with the straight six and timed the engine with #6 until the XJ40 AJ6 engine. Then the numbering went from front to rear and the timing was from #1.
bob gauff
bob gauff
I also saw something that said the firing order is 1,2,3,4,5,6. How creative. Hehehe. I've got a similar cylinder misfiring challenge I'm trying to track down. I took it to a mechanic who specializes in European cars and his Snap On Tools monitor gave me 4 codes, P0300 (multiple cyl misfires), P0302 and P0305 (misfires in #2 and #5 cylinder, respectively) and P1314 (Misfire Rate Catalyst Fault, Bank #2). I've heard that a bad calalytic converter can give misfire symptoms and throws off those same codes, so I hope I'm not chasing something with the misfires that isn't the cause. I replaced Coil #2 already and I'm going to do #5 now and then see how she runs.
FS[MidAtlantic]: 1997 XJ6 VDP $3,900 - Very RARE Anthracite on Warm Charcoal
42Ajd
Sep 26, 2015 07:04 PM
