daimler six 1996 radio and seat memory not working
Hi please can someone help me with the following problems : on my Jaguar six 1996, the radio doesn't come on and the seat memory it's not registering, needless to say that we did check all the fuses......
thank you
Enrico
thank you
Enrico
Look for 12 volts at socket 1 , 10 and 11 and ground at 13 and a ground strap from the case to car . Fuse # 1 / 25 amp , # 8 / 15 amp , # 10 / 5 amp all trunk fuse box . Look for the 2 round cables to be installed if the 8 speaker wires in the group on the right side of the square connector are not installed . The power amplifier is in the trunk on the premium Daimler set up . It should be warm to the touch after turned on a while . 12 volts at connector socket 5 and 12 with grounds at 4 and 11 .
Thank you lady penelope, tried all that but still bot working and just found that also the central locking doesn't work, it works only with the key.........
Any idea ?
Thank you
Any idea ?
Thank you
There is a Jaguar " Hard Reset " that will lose your radio security code sometimes ( anti - theft feature ) but will reset your master security ECU for the doors as I have done before but I didn't lose the radio code ( yet ) . The seat ECU along with others is reset by a button sequence on the radio head . I can't remember or find the 2nd reset other then the " Hard Reset " . Someone with more experience may be of more help then me . Is the radio round connector ( s ) other then the rectangle white connector and the ground strap and the antenna plug installed ? There seems to be a relation to each other and may have been tinkered with in the past and should be restored in a sequence order being radio first . Then remove the radio before " Hard Reset " . Long connection time " Hard Reset " does make a difference vs. short time . Do you have a fully charged battery of near 12.77 volts ? The " Hard Reset " will lose your engines regulation until it relearns it .
there is a jaguar " hard reset " that will lose your radio security code sometimes ( anti - theft feature ) but will reset your master security ecu for the doors as i have done before but i didn't lose the radio code ( yet ) . The seat ecu along with others is reset by a button sequence on the radio head . I can't remember or find the 2nd reset other then the " hard reset " . Someone with more experience may be of more help then me . Is the radio round connector ( s ) other then the rectangle white connector and the ground strap and the antenna plug installed ? There seems to be a relation to each other and may have been tinkered with in the past and should be restored in a sequence order being radio first . Then remove the radio before " hard reset " . Long connection time " hard reset " does make a difference vs. Short time . Do you have a fully charged battery of near 12.77 volts ? The " hard reset " will lose your engines regulation until it relearns it .
hunterpedigo
Jun 21, 2017 08:59 PM
hunterpedigo
Oct 29, 2015 05:31 PM
