diff output shaft bolts
Old Aug 22, 2013 | 10:41 AM
neal222's Avatar
Default diff output shaft bolts
hello. i am trying to get the output shaft off my 1996 xj.
I am trying to get the 5 bolts that hold the output shaft to the diff housing. i can not get them to move at all and i have rounding one of the bolts off. I am worried i will round all the bolts off and i will never be able to get it off.
they are torx bolts. the nearest i can get is an e14 torx. is this the correct socket size?
i have read that heating bolts will loosen the loctite. but will the heat weaken the shaft.
dose anyone have any ideas. thank you.
Old Aug 22, 2013 | 11:58 AM
RJ237's Avatar
Welcome to the forum, neal. Heat is definitely called for. If you use oxy-acetylene don't try to turn them when the heads are bright red, you may twist them off. When you have time, please visit the new member area and introduce yourself. Link below:
New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum
Mac Allan
Jul 20, 2020 05:46 PM
04Xjrsteve
May 7, 2019 04:06 PM
Johnken
Apr 8, 2018 10:21 AM
Dave1109971
Dec 15, 2015 06:16 PM
