Differential Fill problem Help!
Old Jun 12, 2014 | 03:57 PM
Craighead's Avatar
Default Differential Fill problem Help!
I climbed under my car to change the diff fluid today and ran into a problem...
Is there a black plastic cap on my fill plug or did someone use some sort of plastic plug in place of the original fill plug?
I can't get this thing off/out. It just keeps spinning. I don't want to use too much force lest I break it off and part of it falls into the differential.
Can anyone offer any help here?
Old Jun 12, 2014 | 04:12 PM
AlbBolivar's Avatar
That black plug isn't the fill plug. I'm not exactly sure what it is but I think it's the breather plug. The fill plug is about 2 inches under that and you'll need a quarter inch extension ratchet to remove it
Old Jun 12, 2014 | 04:13 PM
al_roethlisberger's Avatar
Question Is that not a breather?
I'm no expert here, but that looks more like a breather than a fill plug
It looks much like the breather on the bevel-box(similar to a diff) on my Moto Guzzi?
Old Jun 12, 2014 | 04:28 PM
Craighead's Avatar
Well that's great news.
I guess looking at it, it looks similar to a Miata diff so that's what I thought it was(fill plug on top, drain plug below it)
This is probably dumb but where is the drain plug that I'm missing?
Thanks!
Old Jun 12, 2014 | 04:30 PM
shaune's Avatar
It is in fact a breather, and will not come off without taking rear-end apart. Luckily just cleaning around it with a toothbrush is all thats needed. Often times the breather gets plugged forcing the fluid to come out of other areas thus making you think you have a bad rear-end. I'd give it a good cleaning then top up the fluid and also use some limited-slip additive if called for.
Old Jun 12, 2014 | 04:36 PM
AlbBolivar's Avatar
Thanks!
The drain plug is going to be directly under the rear end. There's a hole in the subframe. It's a square so you'll need a socket that fits it just right.
Old Jun 12, 2014 | 07:04 PM
Craighead's Avatar
Yeah, that was a dumb question. Been working on a Miata for so long. Both of the plugs are on the back of a Miata Diff.
Anyway.
Got it all done!
Filled it until it was pouring out of the fill hole. Then I let it reduce down to a very slow drip and put the plug back.
Thanks!
FrickenJag
Jun 16, 2025 02:15 PM
bamforp
Aug 14, 2024 05:36 PM
Scarecrow
Mar 28, 2016 03:17 AM
mrplow58
Sep 9, 2015 11:27 AM
laserguy
Sep 3, 2015 02:02 PM
