Differential Oil
BTW, for those who have a Powr-Lok or other Limited Slip differential, then in addition to the right gear oil you may also need an LSD oil additive to prevent chatter or bumping while cornering.
Cheers,
Don
Redline and Amsoil both have an interesting mid-point gear oil that is synthetic 75w110
https://www.redlineoil.com/75w110-gl-5-gear-oil
https://www.amsoil.com/shop/by-produ...-gear-75w-110/
How much single rear wheel spin will the power look allow before locking up?
I have always assumed my XJR has the LSD. Certainly the rpm in 5th gear match the ratios for the 3.27 LSD and 290 Getrag gearbox
The other day I got a wheel on the grass verge and spun it up - the speedo climbed about 30 km/ h too high, so a fair bit of single wheel spin.
But I have no idea at what wheel RPM the LSD clutch pack should start to lock. Interesting question. Also I'd assume that the LSD comes on gradually, not binary on/off.
The spec to break away is between 50-80 ft-lbs. It's not a huge amount, otherwise you'd never be able to turn a corner.
The locking part is actually always locked, it unlocks when needed, such as when turning.
The way to tell if you have LSD is to jack up the rear of the car and leave the shifter in neutral. Spin a wheel by hand. If the other wheel moves in the same direction, then you have LSD, if it moves in the opposite direction, you have an open diff. Another test is block one wheel to prevent rotation - wedge a piece of wood under it for example. Then turn the other wheel. If it turns easily, you have an open diff.
