Dimple wheels confusion
I'm looking to buy a set of Dimple wheels for my newly acquired X300 XJ6..
I noticed there are 7J and 8J versions available for the Dimples. Should I get the 7J or 8J if I'm looking to get a more classic/elegant look?
What are the differences between the two? I see that the 8J is slightly more 'concaved' than the 7J - apart from that, is there any other difference?
Thanks!
Thanks!
7J and 8J refer to the width of the wheel, i.e. 7 inch and 8 inch wide.
With the wider wheel you will need to fit wider tyres with a lower profile. So the 7J wheel should have 225/55/16 tyres and the 8J wheel should have 245/50/16 tyres.
I think the 7J is a 17 inch wheel used on the X308 model
I have seen a version of my 16 inch dimples in a larger version but the same dimple pattern
https://www.jaguarclassicparts.com/u...e-alloy-dimple
You can rattle around on this websight and see if you find the 7J
plums
Jun 27, 2015 11:02 PM
toutlnone
Jan 22, 2009 06:26 PM
