Doing water pump... do chain & tensioner while at it?
Old Sep 9, 2011 | 06:05 PM
Censport's Avatar
Default Doing water pump... do chain & tensioner while at it?
So I was replacing a fog light bulb earlier today, and looked up to see the water pump leaking a bit. Already have one coming, but I got to thinking that I should go ahead and do the timing chain and tensioner while I'm in there. My '96 has just a tick over 105,000 miles on it, and I don't know the service history prior to buying it five years ago. Would you?
Old Sep 9, 2011 | 06:18 PM
Doug's Avatar
You won't be going "in there" very far when replacing the water pump so the timing chain is scarcely a related job.
Chains seldom fail on these cars anyway. The little hydraulic tensioner thingy has been known to give problems, though. It's externally replaceable but not related to a water pump job.
Old Sep 9, 2011 | 06:53 PM
pan84's Avatar
where there? under the hood? Water pump on xj not under timing cover, like on most other cars, if chain is not make any noise just leave it. Water pump just 2.2 hours labor and 10.8 hours labor for chain. While you replace water pump, you don't need to remove chain cover.
Old Sep 10, 2011 | 08:42 AM
Censport's Avatar
I thought it looked separate, but didn't know the spread on the hours. 8.6 is a big spread. I'll look at replacing the tensioner, as the chain does rattle a little when starting cold.
04Xjrsteve
May 7, 2019 04:06 PM
JAMES1944
Sep 29, 2015 11:58 AM
bydand
Sep 28, 2015 09:47 AM
bydand
Sep 27, 2015 12:00 PM
