Door exterior lower window trim strip removal
Old Jul 9, 2021 | 05:50 AM
V126man's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
Active Streak: 90 Days
Default Door exterior lower window trim strip removal
1996 X300 3.2. Does anyone have any advice as to how to remove the door exterior bright metal window trim strip fitted at the top edge of the door skin? This strip also has the exterior door window seal attached at the back. Just to be clear - on the front doors it is fitted along the top edge of the door skin immediately below the door mirror. Thought I would ask before blundering in. Also, is it possible to remove the bright metal trim around the rear quarterlights. This seems extremely difficult to move at all and may be bonded to the quarterlight itself.
Old Jul 9, 2021 | 03:14 PM
b1mcp's Avatar
The trim piece you are referring to is called the Door Waist Finisher/Seal. The piece is simply a push fit on top of the door using spring clips. To remove you need to lever it upwards carefully and slowly.
A word of caution here. These trims are prone to corrosion internally (aluminium) and that makes them fragile. It would be easy to destroy them when removing. Be aware that most if not all are NLA and good used ones are very rare at least in the UK. If you can get hold of new ones they are very expensive.
The rear quarter light (called a six light by Jaguar) is a single unit glass and trim so you cannot remove the trim without the glass which is bonded to the car body.
Old Jul 10, 2021 | 02:41 AM
V126man's Avatar
many thanks Brendan.
Old Jul 10, 2021 | 12:04 PM
Parker 2's Avatar
I was able to find one on E - bay from a salvage yard in California
$ 30 US and was in great shape
I can find the link if you would like and you can e-mail him
This link bellow is for a different part but his ask seller a question link is on the page
https://www.ebay.com/itm/17439215556...4AAOSwj5xfNVV1
Old Jul 10, 2021 | 03:36 PM
V126man's Avatar
Thanks. My trim is not damaged (yet - as I have not tried to remove it ha ha ).
I wanted to know how to remove as I need to get some body work done and would prefer to remove the trim rather than have it masked.
Old Jul 10, 2021 | 04:03 PM
Parker 2's Avatar
Remember there is a fastener screw/clip on the back aft most point
Riley VanSuetendael
Apr 9, 2021 02:23 PM
Portfolioxfs
Mar 14, 2020 10:31 AM
JTsmks
Nov 21, 2015 11:57 AM
Sean W
Aug 20, 2014 12:16 AM
Car-Nut
Feb 21, 2011 07:26 AM
