Door lock cable keeps breaking. Any way to reinforce it?
Old May 29, 2024 | 05:21 PM
madijag's Avatar
Default Door lock cable keeps breaking. Any way to reinforce it?
In 2 years, I've broken the driver's door lock cable 3 times.
Before I replace the cable again (easily a 2 hour operation), do you guys have any guesses as to what I'm doing wrong?
It works fine for a while, then it seems I have to pull the handle further and further away, until the door doesn't open or the cable snaps.
I wonder if the switch is flaky or maybe the lock mechanism needs to be greased to work smoother.
Thanks.
Old May 30, 2024 | 08:35 AM
Bill Mac's Avatar
I have replaced this cable on both X300 and XJ40 cars
You need to lubricate the door lock. Just spray it with WD40 or similar to degrease the system
I then spray a 50/50 mix of SAE30 and mineral turpentine.as a lubricant.
Rough but it works.
mayhem
Aug 17, 2024 11:45 AM
Amphicar770
Mar 23, 2022 01:50 PM
Wares
May 20, 2017 01:14 PM
nickxj6
Apr 1, 2015 06:29 PM
paulsturbo
Aug 25, 2010 04:57 PM
