Driver Side Kick Panel
Old Jan 2, 2024 | 10:20 AM
odpuskas123's Avatar
Default Driver Side Kick Panel
Hey guys, I am trying to get to some electrical wiring behind the kick panel to the left of the driver's feet, but I can't see how to remove it. I tried tugging around the edges but it didn't come loose and I don't want to break it. Anyone know how to remove it? Should I just pull harder or is there something else I should do?
-Thanks, Oden
Old Jan 2, 2024 | 02:04 PM
Parker 7's Avatar
Pic ?
Do you have a left or right hand steering model ?
Is it the center console ?
Old Jan 3, 2024 | 11:47 AM
It is left hand steering.
Here are some pics.
There is that plastic pin that looks like it is holding it on but I don't know how to take it off. I tried pulling on it but it wouldn't come loose.
Old Jan 3, 2024 | 01:44 PM
b1mcp's Avatar
The stud you have that is holding the trim panel on is not the correct one.
The original stud is a 1/4 turn fitting with a slot in the head and is easy to remove. Over the years these get broken/lost and people just put some generic fitting in there to hold it. Usually a Fir Tree type fitting.
You need to get that stud out - either using a trim tool or cutting the head off it with a sharp knife or chisel. Then pull back the furflex door aperture trim and the panel will be easy to remove.
For info, the original stud fitting is AGU 2229 (plus a colour code depending on what you have).
Old Jan 3, 2024 | 04:02 PM
Hey thanks. Makes sense now.
-Oden
Old Jan 3, 2024 | 09:05 PM
Parker 7's Avatar
With a fir tree type interior trim fastener you can get under the head with a 10 dollar auto trim tool
It will pull straight out like a nail in wood
Replacement fastener common on auto parts store rack
TheMaitham
Jun 16, 2025 11:37 AM
JDog
Jan 28, 2023 09:24 PM
SovietKitsch
Jul 19, 2017 01:43 PM
xjr2004
Mar 10, 2011 09:04 AM
