Drivers window jumping
Old Aug 2, 2015 | 10:32 AM
Scorpio stu's Avatar
Default Drivers window jumping
Hi
My 1997 x300 drivers window gets to the top and jumps (for want of a better term). Clicking noises and the window stops a few millimetres from the top now.
I took the door panel off but couldn't see anything obvious.
Any help please ?
Old Aug 2, 2015 | 07:45 PM
Memory, HA.
The window motors have an override clutch, so little fingers do not get cut off by the rising window.
The glass "jamming" in the runners will also cause an overload, so drop the window, spray a liberal amount of Silicone Spray on the vertical runners, then bring the window up, then down again, some more spray, etc, and you may just be lucky and sort it.
Those vertical runners do get rather gungy with road grime etc. Just did the Silver S, and now all sweet and silent and SMOOTH. Black beast later today.
Old Aug 3, 2015 | 02:15 PM
al_roethlisberger's Avatar
Is there a recommended (or conversely NOT recommended) lubricant to use in the rubber channels?
I'd hate to gum something up in trying to fix this sometime.
Old Aug 3, 2015 | 07:34 PM
Al,
I have ONLY ever used Silicone Spray in P/pack cans. I also only purchase thw Valvoline, or CRC brands, as I dont trust the "ElCheapo" stuff for this task.
99xk8guy
Sep 29, 2025 10:51 PM
99xk8guy
May 28, 2024 09:36 PM
GordoCatCar
Jan 2, 2017 01:10 PM
Chuck Schexnayder
Sep 18, 2015 03:10 PM
RaceDiagnostics
Sep 13, 2015 02:22 AM
