ECU replacement - 1997 XJ6L
Old Apr 15, 2021 | 11:15 AM
baws's Avatar
Default ECU replacement - 1997 XJ6L
My question is for the unit up under the dash on the front passenger side. Are they specific to the long wheel base cars or year specific?
I suspect mine is not working optimally. Runs fine, no check engine light, however some monitors in the OBDII refuse to reset after a years worth of driving cycles
Thanks!
Old Apr 15, 2021 | 12:09 PM
xalty's Avatar
there’s like a million different configurations and revisions, i have a 96 lwb pcm in my 97. i still have a spare that i replaced for what turned out to be a TPS issue but i can’t guarantee it’ll work good.
unless you have a running issue or emissions testing i’d leave it alone
Old Apr 15, 2021 | 12:31 PM
Parker 2's Avatar
The unit up under the dash is the Body Processor Unit and can be reset by a hard reset procedure
Below that and in front of the right front door hinge is your engine ECU
The TPS sensor mounting effecting the idle stop voltage back to the ECU must match the ECU " orientation "
This orientation or setting is hard to change or find out what it's set to to get the TPS to match
To get them to match requires some trail and error work unless you are lucky to find a already ECU match
nielda800
Mar 11, 2019 12:17 PM
AMC
Apr 21, 2018 11:06 AM
Madbrad
Jul 22, 2015 07:49 PM
mvagts
Oct 25, 2011 12:23 PM
mr smith
Oct 19, 2009 04:24 PM
