Electrical connectors for washer pump and level sensor? Source?
Old Sep 30, 2013 | 05:47 PM
Dan Bennett's Avatar
Default Electrical connectors for washer pump and level sensor? Source?
Anyone know where I might find these? I wish I had a donor car then I'd just cut them off and splice the wires together. Got all my parts in but these.
Old Oct 9, 2013 | 12:28 PM
Roger95's Avatar
I believe these are the parts needed (after much research on my part)
Amp Econoseal J Weatherproof Connector Assembly, 2 position.
Old Oct 10, 2013 | 08:25 AM
Thanks! VERY much. I'm getting some leads googling that out but nothing solid as far as a place to purchase. But thanks regardless!!!!
Old Oct 10, 2013 | 08:50 AM
Roger95's Avatar
You're welcome Dan, I have the same problem and began chasing this down some time ago and believe me it wasn't easy! I think any electronic parts distributor (Arrow, Newark and so forth) can supply.
Old Oct 10, 2013 | 05:46 PM
Roger95's Avatar
I nailed it, I know just what we need and I should be able to post part numbers in a bit.
Old Oct 11, 2013 | 07:22 AM
Roger95's Avatar
These are the part numbers we need:
AMP Econoseal III .070 series socket housing 344276-1 (female)
AMP Econoseal III .070 series pin housing 344274-1 (male)
Contact extraction tool P/N is 1-1579007-5
Standard color shipped is black which is the color of the washer pump
The fluid level sensor color is red which is shipped on request. The fluid pump and the fluid level sensor take the same part number with the only difference being the color (black, red).
99xk8guy
Sep 29, 2025 10:51 PM
Sprayall
May 30, 2021 08:13 AM
al_roethlisberger
Sep 11, 2015 10:04 PM
Sprayall
Sep 3, 2015 07:49 PM
KarimPA
Sep 3, 2015 07:32 PM
