electrical ignition problem
Old Aug 6, 2009 | 09:38 PM
cooke's Avatar
Default electrical ignition problem
Got a question for you its an ignition switch question. When I turn my ignition off and take the key out, everything should be shut off but with mine all the windows work the radio stays on and the sun roof operates. Is that a relay problem or an ignition problem?????
Old Aug 7, 2009 | 05:45 AM
sparkenzap's Avatar
cooke:
That could be a number of things, including s relay. Do you have a test light or meter? Doyou intend to troubleshoot it yourself? Do you have a schematic? We can walk you through it.
Old Aug 8, 2009 | 09:29 AM
cooke's Avatar
Let me see what equipment I can put my hands on and I'll get back to you.I'll PM you first then I'll put it on the board.
Old Aug 8, 2009 | 09:55 AM
sparkenzap's Avatar
That works for me.
Old Aug 9, 2009 | 08:11 PM
cooke's Avatar
Default possible theory to the electrical problem
I was talking to a friend and he said, one of the problems with the electrical system in the X300's is the insulation around the wires in the wiring harness fuse together which causes shorts in the system. Can anyone respond to this statement?
Old Aug 10, 2009 | 09:55 AM
sparkenzap's Avatar
Never heard of that.
99xk8guy
Sep 29, 2025 10:51 PM
dsnyder586
Dec 29, 2024 07:39 PM
XJsc-guy
Nov 23, 2015 01:56 PM
jdzubas
Oct 4, 2015 09:14 AM
mcdutch
Sep 4, 2015 03:38 AM
