Emergency Brake Light staying on
Old Jul 6, 2013 | 11:16 PM
Boeingtravel95's Avatar
Default Emergency Brake Light staying on
Recently noticed my emergency brake light stays on after the brake is off and it flickers as I'm driving. It doesn't flicker in a specific pattern but it just does at odd times. Any clues on what this could be....also I checked the brake fluid level and its full. Thanks
Old Jul 6, 2013 | 11:50 PM
Suede's Avatar
Your handbrake switch is either loose, or failing. It's a simple contact switch held in place by 2 phillips screws with 2 wires, so first lift up the handbrake leather boot and have a looksy. If you're lucky it'll be jiggly and a half turn with a screwdriver will fix all. If you're unlucky, that piddly little bugger will set ya back $75 (or you could just unplug it)
Part # -LNA6531AA
99xk8guy
Sep 29, 2025 10:51 PM
H20boy
Dec 24, 2024 03:23 PM
99xk8guy
May 28, 2024 09:36 PM
Jpav27
Jul 31, 2022 06:43 AM
motorhead69
Sep 9, 2015 10:04 AM
