Engine smoothness.
Old Oct 29, 2018 | 05:17 PM
Tbilisi79's Avatar
Default Engine smoothness.
How smooth is this engine supposed to be. I’m a long time Lexus owner, so I know my standard is high in that regard.
Are the 4.2 engines very smooth?
Reason im asking , the engine is a bit harsher at higher rpms. Say 3000.
I was wondering perhaps the tranny mount is worn out ?
Car only has 45 k miles.
Thank you
Old Oct 29, 2018 | 06:29 PM
Robman25's Avatar
Are you on the correct thread? The x300 did not come with a 4.2 engine, only the 3.2, 4.0 I6 or the 6.0 V12
Old Oct 29, 2018 | 07:32 PM
Tbilisi79's Avatar
Sorry. I meant 4.0. Mine is 1997
Old Nov 1, 2018 | 02:43 AM
SleekJag12's Avatar
The engine should be "smooth" across the rev range. That doesn't mean there won't be any vibration or noise, as in a Lexus... which are known for "smoothness". Lexus typically isolates their engines very well.
In my experience, the properly running AJ16 will still show a slight "shake" at idle in Park. It might just barely be felt in the cabin. However in Drive, it should be dead smooth and quiet when stopped at idle. On the road, the AJ16 puts out a pleasant but noticeable growl under acceleration, coming to the point of "loudness" at the higher revs. The power delivery should be smooth. But compared to a Lexus, the Jag might seem "noisy" or maybe "harsh" as you say.
Of course, the age of the car matters. Our Jags are getting older and rubbers are deteriorating everywhere, including the engine and transmission mounts. That dry, hard rubber will transmit more engine sound and vibration into the cabin, particularly from the transmission mount. Plus the AJ16 is sensitive to the ignition coils and improper ignition will cause vibration whenever it happens.
I prefer to hear some engine sounds from my car. I don't care for the muted and almost "invisible" engines so many automakers have decided that people prefer. Like Lexus?
I'd say a new transmission mount would be the best step towards reducing engine noise. I have that job planned for my XJ12, as I notice too much engine "drone" on the highway. It's worse than it used to be and I know the rubbers are flattened to nothing.
Old Nov 1, 2018 | 05:30 AM
Tbilisi79's Avatar
Thank you for your input.
Engine is quet and snooth at idle and in drive.
The only harshness I detect is in the upper rpm range. Same sharpness can be detected at 70mph. It’s more central so can’t blame the tires. I’ll take a look at the tranny mount and see what’s going on there.
Ive had tired tranny mounts give off all sorts of unpleasant vibes in one of my Lexus cars.
ianann12
Aug 23, 2023 09:18 PM
bcvanbelle
Jul 23, 2012 01:40 PM
red ink
Apr 7, 2010 01:50 PM
texmanmoore
Jul 1, 2008 10:53 PM
michaelnv
Feb 4, 2007 05:14 PM
