Is a few inches enough!
Old May 12, 2012 | 12:23 PM
spencerikin's Avatar
Default Is a few inches enough!
Hi Guys
Right then I still need help with my aerial. New mast and cable have arrived and I've installed them, but the aerial will only go up and down a few inches.
Any ideas?
Looking forward to your help.
Spencer
Old May 12, 2012 | 05:21 PM
Anyone????? S
Old May 12, 2012 | 05:38 PM
TopHatChef's Avatar
I'm thinking it may not be properly installed. I had issues with installing a new antenna. I had to take the motor off/out of the car, and manually install the new antenna.
Old May 13, 2012 | 03:14 AM
So I've taken the aerial out of the car and striped it down all the way, cleaned the cogs and everything. I didn't put the cogs back in but powered it back up again including the aerial connection. When I turn the radio on and off the motor spins for probably a second and then stops. Surely the motor should continue to spin until the cogs feel resistance, or at a push the time it takes for the aerial to retract - I'm guessing 5-10 seconds depending on how fast you would like the aerial to retract. Any thoughts? S
Johnken
Apr 8, 2018 10:21 AM
noterman
Nov 7, 2015 06:18 AM
Lubrication
Oct 1, 2015 03:56 AM
caldoofy
Sep 28, 2015 08:43 PM
