Flickering interior lights?
Old Dec 10, 2007 | 04:32 PM
GordoCatCar's Avatar
Default RE: Flickering interior lights?
Bad Ground connection
Old May 22, 2010 | 04:38 PM
kumanyoko's Avatar
Hi JagSnawb, I see your post is some years old but my '95 Doublesix is doing the exact same thing as yours. I have to assume you got yours fixed by now and would really appreciate knowing what the problem was.
Was it a bad ground connection like GordoCatCar said?
Thanks, Scott
Old May 23, 2010 | 02:34 PM
motorcarman's Avatar
It is the door latch switch that fails and if it is the driver's door it will also make the tilt/reach steering column 'go crazy' if the 'auto' feature is enabled. The column motors will 'judder' because the door switch signals the module that the door is opening and closing rapidly.
bob gauff
Old May 24, 2010 | 02:49 AM
kumanyoko's Avatar
Default sorted
Pulled the switch today and cleaned it out with circuit/contact cleaner and compressed air. Problem solved. Thanks very much.
Old May 30, 2010 | 02:56 PM
Teck4Jag's Avatar
sounds like a bad door latch micro switch ,it comes with a new latch
H20boy
Dec 24, 2024 03:23 PM
redrover41
23
Sep 25, 2015 01:33 PM
hoodun
Sep 14, 2015 01:26 PM
giandanielxk8
Sep 6, 2015 07:21 PM
King Charles
Sep 3, 2015 12:40 AM
