A frame bushes
Old Aug 17, 2013 | 06:02 AM
sogood's Avatar
Default A frame bushes
Simple question. When replacing the rear A frame bushes, are they a simple "press fit" or are they also glued in place, with some special adhesive?
Many thanks.
Old Aug 17, 2013 | 06:57 AM
There used to be a lubricant/adhesive to use when fitting these but it's no longer available.
A squirt of WD40 makes pressing them in a bit easier. Provided the A Frame isn't corroded, they aren't going to fall out.
Old Aug 18, 2013 | 03:47 PM
sogood's Avatar
Thanks for that and I kinda thought as much. I vaguely remember reading a post that mentioned some sort of adhesive, but thought that seemed to be a bit of a "belt and braces" approach, given the set up.
Thanks again.
TreVoRTasmin
Feb 23, 2021 03:13 PM
NTL1991
XJ40 ( XJ81 )
May 1, 2017 07:54 AM
Chuck Schexnayder
33
Oct 24, 2015 10:20 PM
brgjag
Oct 6, 2015 09:27 PM
