A Frame Bushes
Old Jul 4, 2016 | 04:14 AM
sogood's Avatar
Default A Frame Bushes
I've developed that common clunking from the rear suspension and some new bushes etc. are due. I also want to replace the A frame bushes while I'm at it and my question is, are the A Frames common across all x300 years? I'm assuming so as I have the one from my donor car removed and thought that it would save some time and hassle if I got it fitted with the new bushes and then just swapped it over to my daily driver.
I'm assuming, from what I've read, that the new bushes will have to be pressed in at a garage with the right equipment.
Doing it this way saves "down time" and allows me to drive to and from the garage. Daily driver and donor car are both Sovereigns, 96 and 97 respectively, 4.0l and 3.2 respectively.
Thanks in advance.
Lawrence
XJ40 ( XJ81 )
Apr 3, 2016 07:20 AM
guygamps
Mar 26, 2016 04:01 PM
IronCobra
Jan 31, 2007 08:24 PM
