Front Upper Control Arm Removal
Old Mar 9, 2015 | 10:46 AM
SD96XJ6L's Avatar
Default Front Upper Control Arm Removal
Just a quick question, I have the detailed instructions for the full front suspension removal, however, I just received my Uro front upper control arm bushings and want to tackle them first.
I know it can be done without removing the spring, however, are there any safety precautions I may not be aware of?
Also, are the bolts one-time-use or can they be re-used?
Thanks in advance.
Old Mar 9, 2015 | 12:47 PM
Japthug's Avatar
Putting a jack to support the lower arm is essential, but other part is straight forward.
Bolts/nuts can be reused.
When you do the left side arm, you will have to remove the suppressor which is attached to eliminate the alternator noise. Please see attached photo.
Old Mar 9, 2015 | 06:33 PM
SD96XJ6L's Avatar
Thank you! I had no idea there was a suppresor!? I've been around cars my whole life and never heard of such a thing!
Old Mar 9, 2015 | 07:03 PM
SD96XJ6L's Avatar
What about actually getting the bushings out? Is a press a must for these. I think I read that it can be done without...
Old Mar 10, 2015 | 10:12 AM
Japthug's Avatar
It's far easier with a press of course, but if you do it without a press you will need to take a lot of time.
Drilling out the rubber part, then push out the inner collar/hat. Gently cut the collar with jigsaw from inside and the tension will be released and you can pull out the bush wholly.
You could press in the bush with long bolt and nut method.
Harry Dredge
Sep 3, 2015 03:04 AM
Harry Dredge
Sep 2, 2015 02:26 PM
XJsc-guy
Sep 2, 2015 11:43 AM
MC36
US Lower Atlantic
Sep 1, 2015 07:34 PM
