front wheel spindle nut torque spec
Old Nov 16, 2009 | 08:02 AM
Doug's Avatar
Originally Posted by hennebear
looking for the tourque spec on a 96 vdp front wheel spindle. Also advise on changing grease seal. thanks.
There is no torque spec for the spindle nut. Tighten the nut enough to ensure the bearings are seated, loosen the adjustment, and then take it down again to *just* achieve zero free play as you wiggle the brake disc by hand.....or as close as you can get.
The seals are a real bear in my experience. They fit onto the spindle, not onto the hub. A piece of PCV pipe is a helpful DIY installer tool.
I have vowed to never replace them again unless there was a clear sign that they were leaking.
Others will chime in
Old Dec 26, 2009 | 02:36 AM
panchostatus's Avatar
I'd rather change a head gasket on a taurus than replace the grease seals for the front hubs.
I'm kidding of course, but you get the idea.
Old Jan 8, 2012 | 03:12 PM
alex0866's Avatar
If you put the new grease seal in hot water for a couple of minutes and then a little grease on the stub axle it'll go on with a good hard push. need very strong thumbs though..... good luck!
hunter34
19
Sep 14, 2022 11:09 PM
PMKimpton
Aug 3, 2019 08:22 PM
jdzubas
Oct 4, 2015 09:14 AM
al_roethlisberger
Sep 11, 2015 10:04 PM
prettydaim
Sep 4, 2015 09:13 AM
