Garaged for three months
Old Aug 10, 2013 | 07:30 AM
motomental's Avatar
Default Garaged for three months
Putting car away for three months . Would there be any problems disconnecting the battery?
Old Aug 10, 2013 | 08:54 AM
In a word, NO.
Best thing you cold do in my opinion.
Old Aug 10, 2013 | 09:17 AM
RJ237's Avatar
Connecting a battery maintaining charger is good, but disconnecting would be my preference. Just check the voltage before you reconnect to be sure it doesn't need charging.
Old Aug 10, 2013 | 10:46 AM
My preference for extended garaging would be leaving it on a battery tender such as CTEK.
Second would be disconnecting the battery which will not do any harm. However, before doing this I'd make absolutely certain the luggage compartment unlocks with the key. Standing next to the vehicle in three months time with a fully charged battery ready to refit is not the time to find the lock is seized.
Old Aug 10, 2013 | 11:04 AM
jimbov8's Avatar
For that length of time I would agree to disconnecting altogether.
I would also pump up the tyres to around 45psi to avoid the dreaded flat spots, unless you are putting the car on stands.
CTEK all the time if you have someone, or are able to check on it periodically.
Old Aug 10, 2013 | 11:11 AM
Mikey's Avatar
Irrespective if the battery is connected or not, it should be kept on a float charger.
Never put a car on stands letting the wheels hang- very hard on suspension bushings.
Old Aug 11, 2013 | 12:14 AM
motomental's Avatar
You for the great info.
Old Aug 11, 2013 | 01:46 AM
rob20087's Avatar
If it's safe to do so, leave the windows open slightly for ventilation. Lubricate the locks and give the car a wash and wax polish.
Mac Allan
Oct 27, 2015 04:49 AM
Beardy
Sep 18, 2015 10:00 AM
explorer364
Sep 11, 2015 05:44 PM
Ceckman
Sep 11, 2015 04:38 PM
DuhCar
Sep 11, 2015 10:58 AM
