Gasket worries
Old Nov 22, 2016 | 01:59 AM
drmike's Avatar
Default Gasket worries
My 3.2 X300 has split a coolant hose twice, the same one each time and it is now replaced. However, a friend pointed out that it split when I really booted it, foot to the floor at modest speed like 50 mph and of course it goes off like a scalded cat.
I assumed it was just the water pump working harder that raised the pressure and split the pipe while he mused if it was a head gasket leak causing pressure.
No oil in expansion bottle.
No water in oil
Water level constant
But I haven't booted it since fitting the new hose. I have run it at 4,000 rpm but not played the hooligan.
Any thoughts?
Mike
Old Nov 22, 2016 | 06:47 AM
V126man's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
Active Streak: 90 Days
You can use this from Frost UK to check for head gasket leaks (not cheap at £46.00)
Block Tester Kit for Petrol and Diesels Cylinder Heads / Gaskets | Frost Restoration. Or I believe that you could maybe get a garage to quickly check for combustion gases present in the expansion tank using an exhaust gas analyser.
Old Nov 23, 2016 | 11:38 PM
rads's Avatar
Could be worth checking the engine mounts too?
Old Nov 24, 2016 | 02:04 AM
drmike's Avatar
Because if the engine moves it could flex the hose I guess? I'll see.
