Hard to brake
Old Nov 18, 2011 | 10:33 AM
1happycamper's Avatar
Default Hard to brake
I am now on my 3rd x300. Love these cars. I know enough
about them now to be familiar with most?? of their quirks
and weak spots.
I was lucky enough to find a 1995 xj6 British racing green
with 67200 miles on it. Nice ride.
However... this car takes MUCH more foot pressure to stop
the car! Perhaps twice as much - tough to tell. Is it
possible that a brake booster can be just "tired" -I always
thought they worked -or they didn't. Can the wrong pads
cause excessive brake pedal pressure? What might other
factors be? Thanks so much for your help. John
Old Nov 18, 2011 | 11:37 AM
pan84's Avatar
Air in the system, bad brake fluid (too old), bad pads, air leak in the hose to the booster, sometimes bad brake hoses (broke inside)
Old Nov 18, 2011 | 11:38 AM
BlackX300VDP's Avatar
You could be right about the booster. I do remember replacing some of them years ago but usually for a honking hooting sound from the diagram. I would first check the booster vacuum line and the check valve. Make sure the connection in the intake is clear. Anybody else?
Old Nov 18, 2011 | 11:59 AM
Default Thanks!!
Wow. Impressive response time. The "other" jag site takes sooo much longer to get anyone to chime in.. I will go and check those now. Thanks.
Old Nov 18, 2011 | 12:00 PM
PS: what would constitute "bad" pads? The pads were just inspected and they are only 20% worn..
Old Nov 18, 2011 | 12:43 PM
Doug's Avatar
Different friction material does change pedal feel/effort, so "bad" in this case would be a very hard friction material.
Agreed on checking vacuum supply to the booster.
A booster can be partially faulty. They're not entirely a go/no go proposition. A small leak or faulty reaction valve in the booster can cause low boost....although the former might be more likely to cause low assist/hard pedal on the first stop and then be fine after vacuum is replenished.
Old Nov 18, 2011 | 05:58 PM
motorcarman's Avatar
I have a stack of boxes with faulty boosters from X300s that suffered from the same faults as BlackX300VDP states. If the leak is significant, then the booster will not operate properly. You might even hear a 'hissing noise' from the brake pedal area or in the engine compartment.
bob gauff
Forcedair1
Sep 8, 2025 01:57 PM
PMKimpton
Aug 3, 2019 08:22 PM
Jefro
Sep 15, 2015 01:44 PM
Andrew Fanshawe
Sep 14, 2015 07:40 PM
mikelibera
XJ40 ( XJ81 )
Sep 4, 2015 05:17 PM
