Headlight Lens
Old May 22, 2011 | 06:23 AM
jkjag's Avatar
Default Headlight Lens
Good gents and ladies - I have a1997 XJ6 (x300) I picked up a rock the other week right into the low beam passenger side lens. the Lens burst but protected every thing else.
i have started digging through yards online and everyone wants to sale me the whole headlight assembly.
Do you have any suggestions where i can just get a light or the lens?
Old May 22, 2011 | 07:14 AM
Thermo's Avatar
Veteran: Navy
jkjag, unfortunately, buying just the lens is going to be about next to impossible. The best advice that I can tell you if that you are looking to save some money is to find someone that has trashed the backside of the lens (installing too high of wattage bulb, tore the headlight apart to modify it, etc) and then trying to buy it that way. The person selling it knows they won't get much for it so if you offer them some money, they will more than likely sell it to you.
Just a hint though, when removing the clear lens, you will need to heat it up in say an electric oven, but you want to keep the heat down around 250F (120C). Going much higher than that and the clear cover will start to get soft and then you can have a real mess on your hands. Also, keep the plastic off of anything metal inside the oven. I have found taking a pop can and cutting it in half and using that to support the headlight assembly works wonders. If you let the clear lens touch hot metal inside the oven, it will turn snow white and you won't be able to get that out.
Old Jun 5, 2011 | 01:58 AM
steadicam's Avatar
Default Lens woes
Yeah, i found that out the hard way. Ruined a perfectly good s type lens because it was touching the grill in the oven
Old Feb 3, 2012 | 06:18 PM
cstu's Avatar
The same thing happened to me as it did jkjag. My Jag mechanic quoted me $246 including taxes for the lens (left inner) and $38 labor. Needless to say I'd like to find an alternative.
I also have water in the left outer lens so am I best off looking for a headlight assembly with two good lenses?
Old Feb 5, 2012 | 03:04 PM
sharay38's Avatar
cstu, had the same thing happen a couple months ago. I was able to find the entire assembly on ebay for $100, and my mechanic charged $40 to install. Once I viewed the assembly, trying to figure out how to replace just the lens, I decided this was the best way for me to go.
Old Feb 5, 2012 | 04:12 PM
cstu's Avatar
Thanks, I was also able to find a bunch on car-part.com. Looks like that will be the way to go.
Edit: Got lucky and found one for $65 shipped.
Old Feb 8, 2012 | 09:37 AM
sharay38's Avatar
Glad to hear it. Hope everything works out for you.
Old Feb 11, 2012 | 07:50 PM
cstu's Avatar
Good news...I got it yesterday.
Bad news...the lens I needed most (inner) was broken.
Why on earth would somebody ship something with no protective packaging except for some brown paper? On top of it the lenses were facing the bottom of the box.
Anyway, back to the drawing board.
Old Feb 12, 2012 | 08:57 AM
sharay38's Avatar
OUCH! Hope you have some recourse
Old Feb 13, 2012 | 05:36 PM
cstu's Avatar
E-Z Auto Wrecking was great and refunded my payment right away. :thumbup:
Old Feb 14, 2012 | 01:49 PM
sharay38's Avatar
Yeah, thumbs up for E-Z. Unfortunately, leaves you with a new search. Good Luck!
Old Feb 25, 2012 | 05:40 PM
cstu's Avatar
Cost me a little more than the other one did ($100 shipped) but I got it today and every looks intact. I was able to recover the outside lens off the other assembly so it wasn't a total loss.
Old Feb 27, 2012 | 12:51 PM
sharay38's Avatar
Glad to hear things are working out for you!
Old Sep 18, 2012 | 04:55 PM
bliving7's Avatar
Xpel makes some plastic headlight lens protectors that I put on my X-300 after having $200 for a replacement headlight. And that was without a bulb.
bliving7
hoodun
Nov 20, 2022 02:35 PM
kingdom worker
Nov 14, 2020 03:47 PM
Lawrence
XJ40 ( XJ81 )
Oct 1, 2015 08:36 AM
NCJagman
Sep 28, 2015 10:31 AM
kevinl
Sep 24, 2015 08:25 PM
