Heater
Old Sep 11, 2011 | 09:07 PM
pan84's Avatar
Default Heater
Hi every one again
Today I check air heater and its not work. I have 2 jaguars about 1 month only and don't try it before. On both cars air just little warm, I will use heater just in the morning time in the winter time (2 month in the florida). Today 93F (34 c) outside and air blow just little warm. It is should be cold outside to heater begin work? Or I have the problem?
Old Sep 11, 2011 | 09:42 PM
Doug's Avatar
Is your temperture gauge showing an "N" reading, indicating the engine if fully warming up? If not the thermostat is probably stuck open....common problem. This will result in weak heater performance.
Next is check check the electric coolant pump that sned coolant to the heater core. They are known to fail. DO you hear/feel it running?
Old Sep 11, 2011 | 11:26 PM
pan84's Avatar
Yes engine temp on the middle.
It have electric coolant pump? no, I don't check yet. So its should be hot? even if outside temp is high?
jazzman20014
Oct 26, 2015 04:15 PM
xjrjag
Oct 12, 2015 03:16 PM
inactualis
Oct 2, 2015 11:13 AM
dickc
Sep 21, 2015 02:04 PM
