Help! Alternator belt tension
Old Jun 28, 2014 | 01:46 PM
thorpyuk's Avatar
Default Help! Alternator belt tension
Hi All,
I've just spent a torrid afternoon (7 hours in all!) trying to replace all three belts on my XJR.
The aircon & drivebelt were easy enough, but I'm really struggling to get the right amount of tension into the alternator belt.
Taking it off was a real pig - I slackened the 13mm bolt at the bottom of the threaded rod (tensioner adjuster), and the 10mm bolt on the top of the tensioner adjuster (above the alternator), and also the 17mm bolt through the bottom of the alternator as mentioned somewhere else.
It then took me AGES to slowly work the two 15mm (not 14mm on mine) nuts down the adjuster rod until I could get the belt off.
My problem is now I just cant seem to get enough tension regardless of how far back up the rod the two bolts go...
If anyone has any advice I'd be extremely grateful! Thanks
Specifically - which bolts should be loose when I'm adjusting the two tensioner nuts? Ta
Old Jun 29, 2014 | 03:42 AM
thorpyuk's Avatar
Well I found out what was likely causing my problem! The tensioner rod is bent!!
Does anyone have one of these from a car they're breaking? I've had a look on ebay :s
Old Jun 29, 2014 | 03:37 PM
Aaron 3.2's Avatar
Either your local dealer or take a look on here, useful site for getting part numbers but parts can also be ordered from them too although I've never used them.
Alternator Mounting-3.2/4.0 Litre - Parts For XJ Series from (V)720125 to (V)812255 (X300) | Jaguar Classic Parts UK
Old Jun 29, 2014 | 10:08 PM
AlbBolivar's Avatar
I actually have one. Let me know if you still haven't gotten one and I can ship this one over to you
Old Jun 29, 2014 | 10:55 PM
aholbro1's Avatar
Hahaha....you bring back a memory from 1984 and Aviation Officer Candidate School (AOCS)
GySgt Kerr: "Who bent the f*&k outta yer rifle, candidate?"
a fellow classmate: "Sir! GySgt Crenshaw, United States Marine Corps bent the f&^k out of this candidate's rifle, sir!"
Gunny Kerr (Eying down the barrel): "Well...the f^*k's bent out of it, that's for sure."
Old Jun 30, 2014 | 10:33 AM
thorpyuk's Avatar
Thanks guys - have managed to find one though!
mikiep
Dec 20, 2019 07:37 PM
10 XF Premium
Oct 2, 2015 09:22 PM
waynepaulj
Oct 2, 2015 04:05 PM
millertic
Sep 30, 2015 08:11 PM
