How Awkward is an Interior Swap?
Old Feb 1, 2015 | 05:55 AM
Daim's Avatar
Default How Awkward is an Interior Swap?
hi,
I'm looking for a replacement for my XJ6 and only come across interiors in beige, grey and creme. Not my taste. My crashed XJ has an all black interior (as it must have). So I was cinsidering to swap all parts.
Wheel, dash, instrument cluster, door cards, seats (are the seats prewired to be electrically adjustable or would a harness swap be needed at the same time?), and carpets.
Has anyone atempted to do this? I really don't want to have a bright interior... And as I need a car rather soon, I've got to ask...
Damien
Old Feb 1, 2015 | 09:12 AM
Damien,
On your list, I've previously changed everything but carpets so it can be done. Once the seats and the console are out then the only difficulty with the carpet appears to be having to remove the sill treadplates to release the outer edges.
Seats could be the big problem. Depending on the Model Year/spec of the donor/recipient vehicles, there's several changes of seat part number throughout the X300 production which could indicate electrical differences. I would compare both VIN
numbers in JEPC before committing to buy.
Old Feb 1, 2015 | 09:27 AM
Daim's Avatar
Hi Graham,
donor is a 95, receiver a 97 (at least planned so far).
So the seats might be tricky part but dash with airbags and co are all interchangeable? Is it a straight forward job? I'm sure it will take a day or two...
Does the instrument cluster save the miles/km driven or the car's ECU (like most modern cars)?
Damien
Old Feb 1, 2015 | 10:41 AM
countyjag's Avatar
Damien,
the mileage is stored in the instrument pack, although if I have understood what you have in mind, that shouldn't be a problem, as the instrument pack is separate from the dash top.
You will be able to swap the dash top from your black interior into the new vehicle, retaining the new vehicles instrument pack and correct mileage.
Old Feb 1, 2015 | 12:36 PM
Daim's Avatar
Originally Posted by countyjag
Damien,
Well my donor cluster is woodfree from factory... So I'd like to carry that over...
Old Feb 1, 2015 | 04:53 PM
b1mcp's Avatar
Check the rear seat belt configuration. It is likely that the 95 has a centre lap belt and 97 has a 3 point centre belt. If that's the case the seat belts and the seats are nor inter-changeable.
Old Feb 2, 2015 | 09:52 AM
countyjag's Avatar
The instrument packs can be dismantled relatively painlessly, and from memory, I think the trim panels could be swapped. Failing which, the wood effect could be painted black?
Old Feb 2, 2015 | 10:32 AM
There's 3 changes of part number for the driver's airbag though the VIN range. The core number HNA9180 stays the same so this may only mean there was a change of supplier or a minor design change.
I'd still be very careful with airbags to make sure they are physically the same dimensions and the electrical connections are identical.
Old Feb 4, 2015 | 10:20 PM
al_roethlisberger's Avatar
Yes, the instrument cluster can be opened/disassembled easily and the fascia lifts right off. So you exchange the fascia for the plain black or faux wood plastic finish if desired.
Painting the faux wood fascia is also an option.
I painted a faux wood fascia black the other day as part of my project to add trim rings to my cluster. I'll post photos once I have it completed.
Old Feb 5, 2015 | 07:19 AM
OWRltd's Avatar
That is real wood, not faux.
Old Feb 5, 2015 | 07:56 AM
Lightbulb Sorry, is it faux wood, not real.
Apologies, don't mean to be argumentative, but the instrument cluster "wood" fascia is absolutely faux wood. It is a hydro dipped faux wood treatment on plastic.
I have both the black and "wood" finished clusters here at the house, and have sanded down and refinished one of the "wood" fascias and they are definitely painted plastic.
Also having disassembled these clusters, it is clear why this piece is plastic. The fascia piece is too thin to be reliably made from wood.
.... to be clear, we are talking about the "wood" finished instrument surround panel inside the X300 instrument cluster. Black on some models like the XJR, faux burl walnut on others.
Old Feb 5, 2015 | 12:26 PM
aholbro1's Avatar
The '95's didn't have a glove box due to fitment of the airbag, whereas the '97 had both. That may create a problem....but it may not.
Old Feb 6, 2015 | 07:39 AM
countyjag's Avatar
Al is 100% correct. There is no real wood in the instrument pack.
Old Feb 6, 2015 | 09:55 AM
Daim's Avatar
My 1995 has (or better had) a glove box...
But heck, it doesn't really matter now... Looks like I'll be looking into an XJ6R instead... They are nearly always black with black interior here and a few ponies more will never go wrong... Just a shame about my super rare cloth black interior... I really liked that more than leather
Old Feb 6, 2015 | 12:17 PM
aholbro1's Avatar
My bad....maybe just the early 95's that didn't get the glove box, then....Or...just noticing your location, maybe ROW MY95's equal NA 96's. I recall some difference as to the MY launch in USA vs. Rest of world (ie. there are 1994 X300's running around that we simply don't have in the USA)
Old Feb 7, 2015 | 07:43 PM
I had read somewhere that the earlier 95's didn't have the glove box, but by later that year they did once Jaguar figured out how it would fit with the airbag.
So if accurate, some 95 models may have a glove box.
H20boy
Dec 24, 2024 03:23 PM
Rivguy
Dec 4, 2020 07:55 AM
Lawrence
XJ40 ( XJ81 )
Sep 18, 2015 02:03 AM
mrplow58
Sep 15, 2015 09:58 PM
jerry_hoback
XJ40 ( XJ81 )
Sep 13, 2015 07:48 PM
