I think I'm going crazy
Old Dec 10, 2008 | 09:18 PM
cprigge's Avatar
Default I think I'm going crazy
Hey Guys, I have a 95 XJ6 with a dead battery. I have been looking and looking for the positive connection in the engine comparment to jump it but can't find it for the life of me. I thought it wassupposed to be on the firewall, at least that's where it was on my 94 XJ6. Can anyone give me an exact location for it?
Old Dec 10, 2008 | 09:53 PM
whiteSTR's Avatar
Default RE: I think I'm going crazy
Connect the positive end (red) clamp of the jumper cab directly to the positive terminal ON the battery, rather than a remote terminal.. but DO NOT connect the ground (black) clamp directly to the battery.. connect the ground to any unpainted/bare metal connected to the body or the frame of the car.. Hope that helps, Eric
Old Dec 10, 2008 | 10:22 PM
Brutal's Avatar
THEYRE THE STUDS ON BOTH FUSE BOXES IN THE ENGINE COMPARTMENT LEFT AND RIGHT. REMOVE THE RUBBER BOOTS OVER THE 13MM NUTS AND CLAMP AWAY, OPUT THE NEGATIVE ON THE ENGINE SOMEWHERE
Old Dec 11, 2008 | 07:23 AM
cprigge's Avatar
Thanks for the replies Eric and Brutal.
Eric, I'm sorry I wasn't a little more detailed in my post, because the problem is that I can't get at the battery. It's electronically locked in the trunk.
Brutal, I was looking at those studs but the wires leading to them are black so I wasn't sure. I'll try them this evening when I get home from work and let you know how that worked.
Thanks again guys, I really appreciate it.
Old Dec 11, 2008 | 08:15 AM
Doug's Avatar
When you're done with the problem at hand you can lubricate the lock mechanism so you can open the trunk with the key !
Old Dec 11, 2008 | 09:15 PM
cprigge's Avatar
Hey Brutal, Thanks alot for the info. It worked. I got in the trunk and have the charger on the battery right now.
And Doug, I've got the key lock soaking in penetrating oil right now too.
Thanks again guys.
JagBrian
Oct 1, 2015 12:52 AM
John Fox
Sep 30, 2015 03:17 PM
sg997tt
Sep 29, 2015 08:13 AM
Bigvettefreak
Sep 28, 2015 03:03 AM
sg997tt
Canada
Sep 27, 2015 02:40 PM
