Idle checklist
Old Aug 15, 2020 | 08:14 PM
  #61
Parker 2's Avatar
Pulling the IAT connector would make infinite high electrical resistance so the thermister sensor circuit should mimic a low temp reading
ECU connector condition on pins X and Y ?
Dip in P is being thought about as you already looked at the transmission connector
Might be at the point of getting the TPS to match the currently sourced ECU
IAC valve clean ?
EGR valve closed
EVAP vavle closed
Old Aug 15, 2020 | 08:29 PM
  #62
xalty's Avatar
IAC valve clean ?
EGR valve closed
EVAP vavle closed
IAC clean but can’t test or it’ll go flying. a new part is cheap so will throw it in
EGR plunger moves freely and rests closed, was also swapped with presumably working unit with no change.
EVAP can be plugged if needed.
Old Aug 20, 2020 | 03:23 PM
  #63
xalty's Avatar
Hmm. When shifting from N to D timing momentarily retards 6 degrees from when the dip occurs timing retards 6 degrees for a split second.
Oh and the missing is back, crank sensor still has original lucas branding so that’s going into the trash very soon...
Old Sep 2, 2020 | 09:26 AM
  #64
xalty's Avatar
Ok long story short, idle dips were resolved by changing the IACV which was missing the o-ring. Intermittent misfire and bad fuel trims were resolved by changing the ECU with matching TPS to avoid adaptations.
Spikepaga
Jul 19, 2017 03:53 PM
albjerryg
Sep 23, 2016 12:51 PM
orangegoose
Jul 14, 2013 05:49 PM
rusbel
Jul 17, 2009 08:35 PM
