Inertia switch location
Old Apr 20, 2020 | 09:27 PM
44lawrence's Avatar
Default Inertia switch location
Does anyone know where the inertia switch is located on my US 95 VDP 6cyl 4.0 ? Also how many fuses & relays are there in the fuel pump circuit ? I know of the 30 amp fuse & relay with the green plug used for the fuel pump in the trunk/boot. Thanks
Old Apr 21, 2020 | 11:41 PM
nunger1330's Avatar
Not sure on the amount of relays on a 95 fuel circuit, but I think the inertia switch is on the right by or behind the side kick panel. I’m assuming you have no fuel by your questions.
Did you put direct power to pump through relay plug to see if pump kicks on? Pump will work regardless of switch and other potential relays, but if switch tripped I believe you still wouldn’t have spark. Good luck.
Neil
Old Apr 22, 2020 | 07:33 AM
44lawrence's Avatar
Thanks for the reply Neil. Yes that's where the inertia switch is located on my 95. The no start problem was the car was not getting gas, fuel pump wasn't turning on. After the usual relay, inertia testing I figured the 4 year old Walbro fuel pump was shot. The fuel pump problem was not the pump but the black "pigtail" wire on the pump's plug was off, WHY????? Soldered the wire back to the connector, preliminary test "turning key on/off" show pump is working.
geneo
May 12, 2018 03:47 PM
jomo
Sep 28, 2014 10:02 AM
e1rfw01
Aug 29, 2014 07:37 PM
giandanielxk8
Feb 11, 2014 01:11 PM
ztbird
Dec 11, 2011 08:57 PM
