Insecure seat base
Old Sep 24, 2016 | 08:40 AM
andyXJR's Avatar
Default Insecure seat base
My driver's seat slides back and forth perfectly well but, rather alarmingly, can be pushed forward and up off the floor at the back, pivoting at the front of the seat tracks.
Has anyone else had this problem? Is it a question of broken brackets?
1996 XJR X300
Old Sep 25, 2016 | 02:06 PM
XJRengineer's Avatar
Hi Andy XJR,
Your symptoms sound very similar to mine. If so, the metal frame has broken where the back joins the base. I bought a replacement seat (in a different trim colour) from a breakers yard and transferred all the trim over from my failed seat. Easier than trying to weld the broken metal frame. Getting the switch out of the frame is the only tricky part, as it is difficult to unclip the plastic tangs that hold it in place.
Old May 5, 2017 | 03:18 PM
andyXJR's Avatar
Is the broken bit in the attached diagram?
Old May 6, 2017 | 01:44 PM
No. My seat frame failed at the point where the back and base are riveted together to form item 1 in the diagram below.
Old May 6, 2017 | 02:04 PM
Another failure is the captive nut (for item 12 in the diagram) pulled out of the floor. See the split arrowed in red:
I had to hammer it flat, spot weld and fit a new captive nut.
omgimali
Sep 15, 2016 05:26 PM
vmaxie
Sep 14, 2016 06:00 PM
adrouin
Sep 9, 2016 01:36 PM
JayW
Sep 6, 2016 03:16 PM
cinqueneuf
Aug 29, 2016 05:39 AM
