Instrument cluster flickers
Old Nov 15, 2012 | 09:03 PM
rmf's Avatar
rmf
I haven't removed it, but am taking the car over to my brother in laws this weekend - he has a car lift in one of his out buildings I'll take a look. Is the IPM accessable from under the car? I'm hoping so.
Old Nov 15, 2012 | 11:51 PM
JackJ's Avatar
The binnacle is the cluster of instrumentation just over the steering wheel and is immediately accessible while sitting in the driver's seat. There are just a few screws to remove to free it.
Old Aug 14, 2016 | 05:10 AM
bogie525T60's Avatar
Originally Posted by johnny9759
97 XJ6 when first started cluster is ok but after car warms up the all the warning lights start to flicker and it looks like cluster is going through a self test. Instrument cluster was replaced and still has same problem. Any one have similar problems?
Believe it or not I had the same problem and it was a bad coil, the car was running well but if you raise your hood at night in total darkness you will see the bad coil, it gloss. I replace it and problem, I read this in this forum and i did not believe it but he was right BAD COIL
Old Aug 14, 2016 | 10:41 AM
al_roethlisberger's Avatar
Thumbs up
Quite an old thread the OP likely isn't following anymore... but still good advice as this happens to owners every so often and elicits quite a bit of frustration and head scratching.
Instrument "light shows" have often been traced back to a bad coil. Odd but true
mhamilton
Oct 8, 2015 02:17 AM
goges
Oct 5, 2015 04:53 PM
mrplow58
Sep 30, 2015 08:56 AM
redrover41
23
Sep 25, 2015 01:33 PM
