before i go taking **** apart to swap my good rear one with busted front one i wanted to see if anyone knew 100% for sure if they were the same front and rear. im speaking of course about LH front and rear (or RH) looking the same to me like switching them would be no prob.
al_roethlisberger
close
- Join DateMar 2014
- LocationSanford, NC
Liked:688 Times in 508 Posts
Quote:
Originally Posted by OWRltd
It appears that they are all different as they all carry different part numbers. There is even a different part number for LWB.
Wow, all different eh? ....
I would imagine they're different for each side but I didn't think they would be different from the same side.
Maybe they include the cable and that is why they're different part numbers?
Quote:
turns out they are nearly identical the only difference is the rear one i took off had a slot instead of 2 holes where you secure the door handle behind the bezel. i swapped my busted front one that had a broken spring and a broken screw inside its thread adapter (or "special bolt") for the good working rear one worked 100%.Originally Posted by OWRltd
i think they have different part numbers mainly cause they like to sell the cable with the handle and the cables for rear are shorter.
