Juddering under load (moved to the correct forum )
Old Jun 22, 2011 | 05:46 AM
Hoggzman's Avatar
Default Juddering under load (moved to the correct forum )
Hi guys, hope someone can help!
I’ve recently just purchased a 1997 XJ8 3.2 with LPG conversion.
It developed a water leak from one of the two hoses that run under the inlet manifold, so I removed this and replaced the two hoses, leak cured.
Now however I am experiencing juddering and loss of power, most noticeable when on the motorway, and asking for power in the 2k ish rev range. If I drop down the gears the juddering goes, but seems lacking in power somehow.
It does this both with LPG and Petrol systems. It also did the BEFORE the hose change for a couple of days but seemed to cure itself.
Any ideas would be very welcome!!
Thanks!!
Steve.
Attached Thumbnails Juddering under load (moved to the correct forum )-sens1.jpg   Juddering under load (moved to the correct forum )-sens2.jpg   Juddering under load (moved to the correct forum )-sens3.jpg
Old Jun 22, 2011 | 09:59 AM
jahummer's Avatar
You might have better luck in the correct forum. This is for 2004 and newer. Good luck.
Jaguar XJ8 & Jaguar XJR - Jaguar Forums - Jaguar Enthusiasts Forum
Old Jun 22, 2011 | 08:47 PM
pdog2000's Avatar
what tool is that you are using? i like those screens...hope your issues work out ok...
Old Jun 23, 2011 | 10:16 AM
H20boy's Avatar
appears to be scantool.net, based on the upper left corner of the screen
JakeXKE
E type ( XK-E )
Jul 6, 2021 06:49 PM
PMKimpton
Aug 3, 2019 08:22 PM
afterburner1
Dec 16, 2015 12:12 AM
MC36
US Lower Atlantic
Sep 1, 2015 07:34 PM
