LED Lighting Question
Old Apr 5, 2010 | 08:07 PM
MTZGR777's Avatar
Lightbulb LED Lighting Question
Mock me all you want for wanting to do this , but I think it would look really cool. I'm sure you've heard of the "flexible LED's" that can go just about anywhere, well I wanted to get two of those and route them on the bottom of both lights so it would have sort of outline the underside of the headlights. Now, I know you hook that up to your battery, only problem is the battery is in the trunk! Any ideas on where to wire it? Also, what fuse should I put it into so that they turn on/off when I turn my lights on/off?
Old Apr 6, 2010 | 10:21 AM
Cadillac's Avatar
Underside of the headlamps ....Well, E Class's new model looks cool with LEDs
However, I would leave it as it though . Still, if you like you could have it just above the park lamps ,in other areas that would ruin your ride
Old Apr 11, 2010 | 01:47 AM
panchostatus's Avatar
easiest thing to do I would say is piggyback off the harness that goes to the wee little bulbs that come on when you flip on the parklamps. its a two wire harness, check with a multimeter, tap into the hot line, and wire in your own grounds.
Jpav27
Jul 31, 2022 06:43 AM
Shawn Svacha
Nov 4, 2019 02:47 PM
bdboyle
Sep 4, 2015 06:16 AM
gene1
Sep 3, 2015 05:58 PM
King Charles
Sep 3, 2015 12:40 AM
