Low beams went out. Not the bulbs. fuses.
Old May 31, 2009 | 04:26 PM
hawaiianjag's Avatar
Default Low beams went out. Not the bulbs. fuses.
The low beams randomly went out but right before it went out i was slamming my sub super hard. and even before they blew if the base was up the lights slightly flickered...anyone else have this happen?
well im thinkin i blew a fuse. does anyone know what type fuse the low beam is on a 1997 jaguar xj6 thanks!
alohaz
Old Jun 6, 2009 | 10:08 PM
HuffdaddyES's Avatar
should be a fuse box under the hood on the left side as you're loking at the car. There also should be a diagram in the fuse box lid as to which one it is. There are replacements in that same box for all different amp levels. Gotta watch the use of the heavy adio electronics like amps and subs. The x300 stock wiring really isn't set up to handle the power draw some of those things demand.
Ben
afterburner1
Dec 16, 2015 12:12 AM
jdzubas
Oct 4, 2015 09:14 AM
redrover41
23
Sep 25, 2015 01:33 PM
UalCapt
Sep 14, 2015 01:42 AM
avern1
Sep 8, 2015 06:25 PM
