Low octane/codes?
Old Oct 10, 2016 | 03:56 PM
95Leaper's Avatar
Default Low octane/codes?
I was wondering if using regular gas instead of premium would trigger a P0420 and P0430 code? Anyone had this issue?
Old Oct 10, 2016 | 04:01 PM
Doug's Avatar
Those are cat converter efficiency codes. Offhand I don't see how octane rating would play in.
I'd stay with manufacturer recommendation but if you wanna experiment your car has knock sensor which detect knocking/pinging...which might well result from the lower octane... and automatically retard the ignition timing to eliminate it. As a result you might feel a loss of power and use a bit more gas.
If you are a very gentle driver and conditions are ideal you might not get any pinging or knocking
Old Oct 10, 2016 | 04:16 PM
95Leaper's Avatar
The reason why I asked was because someone borrowed my car and put in 87 or 89 octane and it was throwing a P0420 and P0430 code. I filled it with premium fuel today and cleared the codes right after. Drove her about 50 miles and no codes so far. And yes,I'm a fairly gentle driver when it comes to my Jags.
Old Oct 10, 2016 | 05:24 PM
Doug's Avatar
Interesting.
I also wonder if it was a difference in fuel *quality* rather than a difference in *octane rating* ?
Let's hear what others have to say
Old Oct 10, 2016 | 06:42 PM
RJ237's Avatar
I have been running 89 octane for three years and no problems. A XK8 forum member has been using 87 octane in his 02 XK8 for at least that long. I think if it's a fuel problem something other than octane rating is at fault.
slojotaa
F-Pace (X761) / C-X17
Sep 6, 2017 12:29 PM
Burnham
Jun 11, 2017 02:44 PM
anoop
XE ( X760 )
23
Feb 6, 2017 01:04 AM
Lubrication
Oct 28, 2016 02:06 PM
geewilicurs
Oct 11, 2016 12:00 PM
