My first 2 years of ownership
Old Jan 2, 2019 | 09:51 AM
Tcasmarcus's Avatar
Default My first 2 years of ownership
Here is an overview of more or less what I have done with the car the last 2 years. Did not include any polishing etc
It is quite a lot .Not everything necessary, but it might be interesting information for those of you who consider buying an old jag...
September 2016 - 135000 km
Airfilter
Sparkplugs BRISK DR17YCY
Engine Oil+Filter
AC cleaner
Cleaned throttle body
new battery Bosch
Brake pads and rotors, front and rear
Brakefluid flush
Windshield wiper
Tightened front wheel bearings
New lug nuts
New MAF
LCD clock repair
October
DAB radio
new bulbs Osram nightbreakers
November
NGK BCPR sparkplugs
December
Andy's brackett
January
2 new oxygen sensors
crank position sensor
February
Rockford fosgate stereo amp
March
New rear wheelarches. Welded/painted
rear a beam mounting bushes (Poly)
April
Engine oil and filter
Fluidfilm anti rust treatment
Automatic transmission flush
Bridgestone tires
May
Flushed differesntial oil
New powersteering servo oil
June
1 front balljoint and upper wishbone bearing
July
Nylon steering rack kit
Welded exhaust manifold crack
New downpipe and cat (dave manners)
August
Airfilter
Windshield wiper engine repair
September
Quicksilver sportsexhaust cat back
December
Jan2018- April 2018 : NIL
May 2018 - 147000km
new brakepads/rotors/calipers rear
Sparkplugs and gaskets NGK BCPR5E
Coolant flush
Paint repairs rear fender
new rear left brake-lamp
Airfilter
June
New front wheel bearing left
July
New belts kit
EBC front brakepads
August
4 new shocks Bilstein/Boge + spring isolators
K&N airfilter
September
New door seal front left
upgraded interior wood panels
Front suspension overhaul kit
October 2018- 153 000 km
Front wheel bearing right
Wheel alignment
******* hose replacement
Old Jan 2, 2019 | 12:42 PM
Alster370's Avatar
That's a huge list! I bet the car feels like a different beast since you bought it. O should say that I've owned my first Jag since April 2017, so I'm fast approaching 2 years of ownership. Besides a good service when I bought the car the only actual items I've needed to do are
4 new tyres
refurbished alternator
crankshaft position sensor
everything else Ive done has been refurbishment work that I've wanted to do, like 700 odd quid on just the ac with new hoses ad that. Still got the rust to sort too.
Can't wait to get new rear dampers on, pretty sure they are the originals, drifts about at high speed and rattles on back end over rutted surfaces
Old Jan 2, 2019 | 12:57 PM
Tcasmarcus's Avatar
You're right it's a different car now. You can look forward to changing shocks. Mine also had the originals and after I changed them the car felt so much more tight and secure at higher speeds.
Old Jan 2, 2019 | 08:18 PM
Lady Penelope's Avatar
Was the video before or after Andy bracket on the crankshaft position sensor ?
Your video is kind of a , kind of a , kind of a turn on , especially when the engine cuts out and the science why
Old Jan 2, 2019 | 11:27 PM
Tcasmarcus's Avatar
Haha.. Glad you like it.
The videos were recorded after I had installed the bracket.
Old Jan 3, 2019 | 05:05 AM
It seems to have gone through an unusual number of spark plugs .......
Old Jan 3, 2019 | 05:14 AM
Tcasmarcus's Avatar
Well.. It was just a matter of finding the correct ones.. The first two pairs were swapped because of faulty maf and o2 sensors a d i was still trying to find the exact culprit for the stalling issues. As soon as this was corrected I decided to go with regular ngk instead of iridium as many reported that the car might dislike these.
I guess iridium plugs would have worked fine once the maf and sensors was replaced.
Old Jan 4, 2019 | 12:58 AM
96x300's Avatar
​​​​​​I've been running the NGK G-power platinums for about 1000 miles and my engine is silky smooth. I didn't want to go with plain copper plugs but with all the warnings I didn't want to spend the $$ on iridium just to risk having to pull them out. They were only $2 and change per plug.
Jon89
Dec 19, 2015 01:41 PM
Jon89
16
Jan 1, 2015 07:32 PM
Rac-Jag
Oct 2, 2014 07:04 PM
jagxkrtoofast
Dec 22, 2011 02:42 AM
