need diff spider & side gears
Old Apr 19, 2015 | 11:47 PM
barchettaboy's Avatar
Default need diff spider & side gears
Hello
I pulled the whole rear end out of my 95 XJR due to noise and band feelings, I was going to replace output bearings and seals but noticed metal slivers inside ( crap ) and could feel a slight notchyness, so time for full rebuild.
I would normally do myself, but do to personal circumstances, chose to use a locale re builder, got a rebuild kit, bearings and seals, but upon them opening up found that the 2 side gears and the 4 spider gears have lots of wear on them. But they are not able to find them, though any of their suppliers. And I have spends days looking as well. Nothing. There are lots of referencing the Salisbury is almost the same as the Dana 44 ( but this is always regarding the early XJ6s series 1,2,3 ) not to mention X300. but I have seen not one post or catalog listing that the internal parts are in fact exactly the same. Can anyone tell me if Dana 44 side and spider gears will if fact work in the Salisbury ? or baring that I have seen a posting about someone putting in a aftermarket limited slip from Summit is that a viable option as well.
I know I could have just bought a rebuilt one from Coventry West but @ $1,100 plus shipping and the $350 core charge and as mine has unusable side and spider gears, that would be $1,450 plus freight.
So if I could get the Dana gears to work great. or even an aftermarket power loc unit for $315 I would be money ahead
So does anybody know for sure if the Dana gears work in the Salisbury ?
Thanks for your help
Darryl
Old Apr 20, 2015 | 08:03 PM
FrozenApple's Avatar
Originally Posted by barchettaboy
Hello
Darryl
Darryl,
I really do not know if thse Dana gears will work or not, but i do suggest that you check the junkyard, there are many x300 sitting in the junkyard and i'm sure one of them has a diff that you can use to strip out for parts and such and its prob going to be alot cheaper then buying a brand new refurb ones.
Jacky
tomsjag
Jun 10, 2023 10:02 AM
danke
Mar 3, 2016 10:57 AM
AtholC
Sep 9, 2015 09:07 PM
1100me
Sep 7, 2015 06:26 AM
Doovoe
XJ40 ( XJ81 )
Sep 6, 2015 10:54 AM
