Neutral Safety Switch
Old Oct 28, 2010 | 05:11 PM
Simprof's Avatar
Default Neutral Safety Switch
Can someone please tel me where this switch is on a 1997 XJR..
Old Oct 28, 2010 | 07:23 PM
Doug's Avatar
It's mounted on the right side of the gearshift assembly. It's actually a multifunction affair....I think it's called a "linear switch" on Jag parlance.
You're having a starting problem, I presume?
I have to jiggle the gearshoft quite ften to start the car. If the "P" is glowing red, the starter will work. If not, I have to jiggle the lever a bit to get the magic red glow.
Fearing that I'll be stranded one day I rigged a remote start button in the engine bay. It bypasses the circuits on the linear switch
There's an adjustment procedure in the manual. I haven't tried it. There's some sort of tool needed...I haven't really researched it too much
Old Oct 29, 2010 | 08:25 AM
Simprof's Avatar
Hello and thanks for the info. Is there away you can explain how you rigged a remote start button in the engine bay to bypasses the circuits on the linear switch
Larry-Cleveland
Sep 28, 2015 10:04 AM
Vector
US Lower Atlantic
Sep 13, 2015 03:01 PM
Wolfy
Sep 11, 2015 06:27 AM
Doovoe
XJ40 ( XJ81 )
Sep 6, 2015 10:54 AM
philwarner
Sep 5, 2015 10:05 AM
